dwarf said:
Ok here’s dwarfs dilemma I know dwarf's not really built for singing. But dwarf would like to know how to carry a song better than he can. dwarfs vocals are weird; they are either low or outrageously high. (I mean like Ben Folds if he was a girl high) how does dwarf train his voice so that he have more mid range?
Or even how does dwarf train dwarfs voice?
Cheers.
(man I love 3rd person)
Okay, Dwarf should purchase a keyboard. It doesn't matter what type.
Dwarf needs to sing "Nay" like a little bratty kid. The notes to sing this on are:
E above Middle C through B/Bb.
And go read this thread for a ton of info I put online about singing and vocal instruction. (I studied privately for quite a while.)
https://homerecording.com/bbs/showthread.php?t=160639
For Basic breath control - get a stopwatch ($15 at your local sporting goods store), hold your breath, and see how long you can hold it. Then, every day for 3 to 5 minutes per day - do each of the following exercises.
hold your breath while timing it.
Slowly release air from your lungs while timing it.
Expel all of the air from your lungs, and instead of inhavling, hold your lungs empty while timing it.
Do each of those 3 to 5 minutes per day.
Then, each day, try to add at least 1 to 5 seconds to each. Do not move on to more time until you have added 5 seconds to all threee and can easily do it.
Then try to add more time, and keep a record of your time.
When you release the air from your lungs, make an SSS sound, and make it is light as possible.
Now, two exercises.
Yawn, then point your chin, and "jut" it out.
#1. When you yawn, it will seat the larynx in a low position. But pointing the chin, you train the muscles to hold it in this position. most untrained singers raise their larynx when they sing, and this cuts off the amount of space within the trhaot, and blocks the pasage of air.
#2. Take your tongue, reach back intoi your mouth, and touch the roof og your mouth with the tip of your tongue. While applying pressure with your tongue, drag it across the roof of your mouth, and let it slide off of your teath and out of your mouth.
Do each of tehse 250 to 500 times per day. When you are done, stick your tongue out, and clamp it lightly between your teeth. with clean hands, grab your tongue and slightly pull on it. (This helps release pressure in your tongue.)
What these exercises do, is train your tongue to lay flat while singing, train your larynx to stay low, and they help train your throat muscles to stay open for what is commonly called "open thraot" singing. (i.e., like Opera style, but it won't take you 7 years to do it.)
Tim
