Well geez if you’re in the market for a consumer quarter-track, $45 for something that can actually be worked on sounds great.
The A-4010 requires oiling of the pinch roller and capstan shaft bearings (I’m assuming they are bronze bushing type bearings so best to use turbine oil), and yes those will seize up with old and-or wrong lubricant, but super-easy fix. The motors require oiling too, but the manual has good instructions for all of that.
And how bad can the belt change be? Can’t be any worse than a cassette deck...at least the parts are all bigger scale on the open reel machine.
I think the pros would be the easier maintenance and repair of a traditional relay-logic machine with no integrated circuits, and the fact the amplifier electronics are 100% discrete. I pulled up the schematics for the A-3340S today. That was my first open reel machine. It sounded really, really nice at the time. I’ll have to pull up and listen to digital archives I have of stuff I tracked on that machine to see if my memories are delusions of grandeur, but I recall recording some electric bass stuff with the bass setup for a really bright sound. I accidentally played back the 15ips track at 7.5ips and I was shocked at the lively clarity that was revealed at the lower speed...and the E string stuff shifted an octave down reproduced clear and powerful...it sounded really nice and it turns out the electronics (except for the headphone amps) are all discrete on that machine too. It’s a more complex circuit on the A-3340S, and I can’t really figure out what the power rails are on each of those machines, but there might be some similarities in character between the two as far as the amp stages. Obviously there would be significant differences due to the 15ips capability of the A-3340S as compared to the A-4010, but for $45? And maybe talk the seller down a little? Seems worth considering. And no I’m not trying to sell an A-4010 OR an A-3350S.
And I understand where you are coming from on the Pioneer machines, but I’ve worked on an RT-909 before...hated it. NOT designed to be worked on easily. This is probably one of the single-most elements that distinguishes “consumer-grade” from “professional-grade” for me. A pro machine presents *some* degree of evidence the people that designed it anticipated it would need service at some point in the field, and at the very least access covers were designed to be easily removed and PC boards were located so you could get to them...and at least some stuff connectorized for easier removal, or in some cases boards were plugin type. The RT-909? Boards are all point to point interfaced with each other so good luck getting just one board out or being able to isolate signal I/O or isolate the power rails...and literally you’d have to about disassemble the whole machine to effectively clean the pots...it’s a pretty machine with a nice feature set, good specs and I think a solid running machine but I’d never want one because I’d dread the day it needs any kind of board-level repair.
The A-4010 looks like things are pretty accessible and the play amps are even on little plugin boards.
