A
AnnieJohnson
I have recently acquired a Teac A-3340 (4 channel) reel to reel tape recorder.
For now I am only working with 2 channels. However when I connect the headphone, I notice there is a slight hum.
When I want to record something and switch inputs to ‘Source’, then hum increases and become much louder (especially on the left channel)
So to summarise, there is hum on both channels but it is louder on the left channel when input is switched to source. It does sound like mains hum and I was wondering if someone had a similar problem on this deck. I don’t want to start adjusting bias levels or randomly changing capacitors everywhere. The heads are in good condition. The manual indicates that it may also be faulty record amplifier or some record relays. I have some questions and would be grateful for some guidance:
Q1 . I think looking at the mains supply circuit capacitors may be a good starting point to address hum?
Q2. Would faulty record relay still allow recording to be made? I can make recordings on both channels
Q3. What should I look out for in the record amp circuit?
Kind Regards
Annie
Kind Regards
Annie
