T
thereelman77
Hi there, first posting on this great site.
I picked up my 2nd multitrack analog recorder recently, a Teac 80 8. I bought brand new RMG911 tape for it to test it out.
First when me and my guitarist ran the initial test of recording guitars it went perfectly well, all functions worked great.
The next day however when I spooled the tape up and pressed play, it didn't function correctly. It began spinning very, very slow, then eventually began speeding up to the point where it was basically in fast forward mode. I didn't know what was wrong until I really looked at it and noticed that the pinch roller wasn't touching the spinning capstan and that it was sometimes staying in place, not moving down completely. I couldn't move the pinch roller to even touch the capstan with my hand. Doing some internet search, I read that sometimes you have to clean the solenoid capstan, which I pulled apart and did, then put it back together, still the pinch roller didn't touch.
My question is that, what could the problem be, bad relays or something? Because when I took the reels off, the motors were spinning fine, no problem. I feared that it may be the motors not being able to handle the weight, but RW and FW functions work no problem.
. So I wasn't able to adjust the 'Limit'. I'm assuming at this point that that is what may need to be adjusted, except that it is completely stripped.
