TDM Plug-Ins. Are these suppose to appear in the AudioSuite menu? ( Where are they? )
  • Thread starter Thread starter underp
U
underp
Member
I'm trying to test some TDM demo plug-ins. Installation is ok, and plug-ins are in "DAE\Plug-ins" folder.
But they don't show up.
Thanks in advance.
PT TDM 6.7
********EDIT************
Don't show up on "Insert Views" either.
Thanks in advance.
PT TDM 6.7
do you have a TDM system? you need TDM or HD hardware units to run them. A 002 or Mbox won't work.
They won't be in audio suite menu unless they are an audio suite plugin format too....but they should be showing up in the inserts though.
No, i don't have a TDM system, and i probably won't have any until 3002.
Is there any other way to taste some TDM demo plug-ins ?
no. TDM requires a TDM card that can process the audio.
Can you get an RTAS version?
I wanted to test the Amp Farm 3.0, but it only comes on TDM.
If it's possible to find better CABs simulators, and it doesn't worth it, then i'll probably forget about a TDM system.
Some people say it's good, and that it's used a lot on commercial music.
Is a 500$ piece of s#it or what ? :P
you probably shouldn't bother even thinking about a TDM system anyway if you're not really clear on how they work.
