B
bryanturner
Hi There
Im having an issue with my usually trusty US-1641 Ill just lay out what im trying to achieve and why first
Im using two computers
Computer 1 - Running cubase 7 as my main project with the US-1641 USB
Computer 2 - Runing cubase 5 with an M-audio Fasttrack Pro for spectrum analasis and osciliscope
My aim was to use the SPIDIF out on the tascam to feed the SPIDIF in on the fasttrack pro thus giving me constant visual feedback on the signal on my laptop set to one side of my main monitor screens.
After trying many different configurations on the main output of individual tracks, the master bus and the sends all I can seem to have available to me are outputs 1 to 4. I have also tried just playing it as normal in the hope that somehow the outputs may be active on the SPIDIF when signal is being routed to the stereo bus but no luck there either.
When I carry out the same technique in reverse it works perfectly (ie) setting the output on the cubase 5 laptop with the M-audio interface to digital out and conecting this to the SPIDIF in on the tascam. When I do it this way I get a signal on an audio track in cubase 7 using a new stereo input bus using digital in left and right with no problem at all. I can play a track on cubase 5 and record it in cubase seven on my main music computer. This works when the main output is assigned to spidif out and it also works perfectly when I use a send as well. This would be the ideal set up for me if it worked the other way around
Is there ANY way to get signal to output from the SPIDIF/Digital out on the tascam at the moment it just seems redundant for some reason.
Both projects are set to 44.1/24bit
Can anyone help as ive just paid 60 bucks for a decent quality SPIDIF cable to be able to analise signals exactly as they sound coming from my main output and cut down on CPU usage. I also want to have my spectrum analiser and oscilliscope running on a seperate screen/computer away from my mix and edit screens.
Please Please heeeelp =)
Cheers
Bryan
Cheers
Bryan
