G
gregoman
I'm looking to recordusing a digital recorder to lay down the tracks such as the Tascam Dp-02, then export each TRACK into cu base for editing and mastering , can I do this? Do I need anything special?
If you've got a solid computer already, then why not get an interface for it and run Reaper to record everything?
Really hope that helps. Recording through an external piece of hardware like the tascam will work, but it seems to be a bit of a long way round if you're confident with your computer already.
I use a dp01fx to track and transfer to my crappy computer to edit and mix bassically cause my computer is to slow to record direct to it and it lags alot no matter what i do. the tascam has zero lag and i can take it out to other sites and record other people quite simply and bring it home and mix on the computer
