Searched for info on the MSR 16..the sequence if I remember correctly for setup and recording a track was power on.. press load + reset for fresh footage settings,press track desired..the tracks red led blinks..to record a track press play+record..red led for record and track now remain solid..The audio level led's on selected track move with audio..Track's audio in = from the mix board.the msr16's rear audio out for that track is connected directly to an external amp. When trying to record a track the audio level leds are active indicating audio in for that track and i can hear it from the external amp..After recording on the selected track its a complete zero..no audio or led activity..replaced the reel with a known master tape....went through what i think is the correct sequence to record on any empty track.. The results were the same..decent audio levels in..audio leds move..audio out to the amp is present and heard..but after recording with good levels on the msr 6 a rewind always ends up with an empty track. not even a slightest movement of the tracks audio level led's.. It does erase a prerecorded track but nothing is recorded. Maybe i forgot the correct sequence to record ..wanted to use this deck due to the remote control and features on the 16th track for sync. something my 3340 or 80-8 doesn't have.
Thanks for any help.
Respectfully
TBean
Respectfully
TBean
