Tascam Midistudio 644 PSU DIY
  • Thread starter Thread starter vladosh
V
vladosh
Hello folks this is my first post here , i got an old Tascam 644 Midistudio but without a PSU , i have built a few PSU's already for other audio equipment and i want to get my Tascam working but i can not find anywhere on the web info on the pin alignment , it's a four pin input on the rear of the Midistudio meant for it's dedicated PSU ( : : ) , i need to know simply the voltages required and the alignment ,please help , i wrote on every possible diy audio forum and no one replied ,so before seeking a fault in it first i want to know if it's maybe even working properly , i really want to get it working ,i've been building audio equipment for a while now i think maybe i can manage it ,if it's just a PSU , Thank you .
Vladko
[ +10 - 10 ]
[ Grd + 7 AC? ]
is this it ? i don't want to plug in anything into before getting some info , it's the Tascam PS-M1 power supply , i don't need the service manual simply the voltage and the alignment ,thank you , this has become a quest .. " too many secrets " :D ,saw someone already posted on this forum regarding the PS-M1 PSU ,anyone with a tascam 644 willing to just measure what's going into it ? Thanks .
Found this info:
TASCAM
AC Adaptor
MODEL NO. PS-M1
Input: AC120V 60Hz 30W
Output: DC+10V 1000mA
DC-10V 1000mA
DC+7V 10mA
I've found no pictures nor done any hands-on testing yet.
Thanks ,i'll look for more info on this one , i just need to know the alignment on those pins in the input so i can test it if it's working ,i wrote tascam few times already but no answer ,thanks ,cheers .
Yeah,...
If I have time I'll break mine out of the box and test the pinouts.
:spank::eek:;)
Thank you a reel person , i think you don't even have to break it out of the box if you have a DMM you can simply measure the voltages on the PS -M1 itself from the outside ,should be doable ,power consumption is good info so thank you ,i assumed it should not be more then 50W
Yeah, but...
my entire 644 w/PSU is in a box, in the closet. I was planning on getting it out to run it thru it's paces at some future time, perhaps to decide whether to sell it or not. As yet TBD. When I get it out, I'll surely test the voltages at the pins.
:spank::eek:;)
It would be great if you look it up ,anytime ..
wanna fix it even just to listen music on it ,i grew up with cassettes and i want it ,the mixer alone looks great ,i posted on all forums i saw on audio or diy ,no one has replied with some info ..i even wrote tascam (few) times ,thanks for all the info so far ,cheers .
I finally got a reply from Tascam ,they sent me a diagram with the pins ,there is one thing that is simply described as AC Signal ..so i need to figure that one out ...
Dude! Sweet!
Do you think you could copy or scan the diagram and post it?
Thanks!
:spank::eek:;)
20140627133520671 (1).webp Here it is , just to figure out the one labeled AC Signal ,maybe that's just +7V DC
If anyone is interested in this older PSU for this series of Tascam gear - I am about to build my first power adapter. It will be without the 7V AC because it's for the MM1 mixer and I think that the odd 7V AC (and a specific frequency as well I believe) is for clocking the tape correctly on the portable studios... (?)
I'm reading up at the moment. Will start the build within a few weeks.
