Hey! Reel! Dave!? Where are you... get up, smell coffee!!!!!!!
.... this guy should know m-30s ....
I don't know these mixers... never had one of these.... so ..
well, just from my general knowledge. As I can tell since it's 8ins/4outs/2subs,monitor outs.... , then you can record 4 line-instruments/mics (to 4 independent tracks) at once with this mixer. Do you need more than 4 input at the same time? If you do, then you can use two m-30s , so you can record up to 8 (instruments / ins) at once ... Or you can submix some of ins, using one mixer.
I am not sure about mic inputs on m-30s. Are they ok? How are preamps? I have no idea. They maybe ok, they maybe crappy
... also depends on your expectations. If i'm correct you have no phantom power on mic ins ... so ... you know, if your mic(s) need phantom, then you need a pre or phantom-box.
If you record only one instrument at the time (or 4 or less) instruments/mics/ins, then you can set one m-30 as your recording mixer, and the second one as your mix-down mixer. (You can do all the same with one mixer thou.... just set it first for recording, then re-patch your set-up for mix-down).
You can mix 8 tracks of your 8-track recorder with one m-30.
what else? You got there phono pre-amps? correct? ....
heh heh .... pretty useless stuff ...lol, well, they are phono-pre(s)... so you can add some vinyl into the mix, if you wish.... again, I am not sure about what I am talking about ...so .... nevermind.
Just keepping you company.
Hey, guys, who got those m-30s ! speak out....
/respects,
