T
tascamstudio
Hi All,
I want to use my Tascam M-312B direct outs into my 8 channel Scarlett Focusrite 18i20 and record directly into my DAW utilising the Tascam Pres and EQs.
I've worked out how to hook everything up and i'm getting a good signal, the EQ is working etc etc. But I can't seem to get my effects unit running through the direct out. I'm using a Roland Space Echo RE-201 which i've plugged into the effects return and send but this isn't being sent into the direct out.
From doing my research I believe the direct outs are post fader so shouldn't I be getting the effects going through the direct out and into my interface?
How would this be possible?
Thanks!
Thanks!
