Sonarcade
Member
I have a mixer that has gunked up and noisy pots and a defective right channel. I had opened up the bottom to reveal that the pcb (if that's what it's called) for the right channel slider snapped in two. I'm not so sure how this would affect the output of the channel, but I suspect that it does. One of the other main screwy things about this mixer is that it has a pot with a lot of play on the "vertical" axis (i.e. pushing and pulling, not twisting along the axis of rotation) -- so much play that I have to push it down to get a signal in my headphones.
I figure that at this point, the pot's going to need replacing. The thing is, I've never worked with installing pots and was wondering if the pot in the picture below is fairly standard and available at Radio Shack. Also, would the pcb need replacing or will some kind of conductive glue fixed the problem? Thanks.
...BUT, it now has an owner that wants to right past transgressions.
...I understand now. You don't actually have a busted board, but the fader is busted as well as the pot...you said that but I got confused...my guess is that something got dropped on the mixer at one point and the master fader and headphone pot took the brunt of it.
