Tascam DP24 External Send Effects
  • Thread starter Thread starter C4th
C
C4th
Hi.
Im looking to put delay on vocals using an external unit.
But i was just wondering how to route this between my DP24 and the delay unit? And how exactly do i use
the Send Effects 2?
Thanks in advance.
connect the effect send 2 output to the external effects unit input, connect the effect unit output to an input channel on the DP24, assign the input channel to a track, use the effect send 2 level to adjust the amount of dry signal sent to the effects unit, tweak the parameter settings and output level on the effects unit and then set the input trim, etc on your DP input channel. arm the track and record. you can later mix the original vocal track with the wet track if desired. I think that sums it up.
