Automation transfer(?) to Cubase
You can back up your Automation info from the DM-24 as a MIDI file. I don't believe you can transfer mix information from the DM-24 to Cubase so that the same automation can run in Cubase. You may want to check with tech support but I believe the MIDI file created when backing up theautomation creates a file that can only be used by a DM-24.
