W
wim
hi there,
i'm wim lecluyse from the netherlands - new on this forum... and botheiring you with a problem from the first post on. sorry!
i have purchased a tascam 488 (the first type, not the mk II) in a second hand-shop about two weeks ago. did some good testing, and everything worked just fine.
but today, i was mixing some recordings, as all of a sudden track 8 disappeared. the recorded music is still there (i checked it by reversing the tape and listeing to track one). but i dont get any signal from it anymore... i also tried recording something new on track eight, but that didnt work either - all the other 7 channels still work fine.
i noticed that when putting on the recorder, you get a slight peak in the signal levels. i get this peak on all levels, apart from track eight...
any suggestions? i read on an other post on this forum (https://homerecording.com/bbs/showthread.php?t=137397) about someone having similar problems. someone also mentioned having problems with track 8 'sometimes' disappearing...
thanks so much!
thanks so much!
