Hey Guys, I have a Tascam 48 that I just modified. The Record Amp cards have all new electrolytics for the power supply rails and Nichicon Muse ES between signal stages. LME49720 and LME49860s have replaced all the op amps except for the VU meter amps. .1uF decoupling caps have been added from pins 4 and 8 to ground off each of the new op amps. All is fine, but I'm having some trouble with noise and drop-outs when recording test tones to my re-calibrated unit. I'm using Quantegy 499, but this problem has exhibited itself on other tapes as well. I believe the issue is not a result of the mods I've made (happening pre-mods as well) but instead the tape path or even heads. The heads have a little wear, but nothing completely terrible. Sending signal to the machine, I've monitored via "Input", "Sync" and "Repro heads. The Input, gives me no issues... sounds perfect. I only hear the issue after listening through Repro or listening back through the Sync (record) head. If I press the "Edit button" and scrub through, I can hear the pops, clicks and rumble that were recorded, but only when scrubbing which makes me think the amp cards are just fine and the issue is, again, the heads or tape path... Take a listen and let me know if any of y'all have any ideas. OR is this something I must live with. Tones were 40Hz, 1kHz and 10kHz https://www.sendspace.com/file/cs7ilf
