Re: MORE QUESTIONS
Pepper249 said:
and even if I did figure it out i think the little sound recorder softwear that comes with windows xp only allows 60 seconds. Thanks again for all your help! .. Patti
Yuck, Patti!
Don't use anything that comes free with any version of Windows. Remember, Bill Gates is the CEO of Microsoft, but he probably knows nothing about recording music. LOL.
As for your Peavy amp with the reverb: I don't see how you can use the reverb from the amp at mixdown. Effects devices work well for that, but I guess you can try it. Try this: At mixdown, trying hooking a 1/4" cable from the Effects 1 Send cable on the 414 to the input of the amp and then another cable from the output of the amp (if you have one) to the Stereo Input 5 & 6 on the 414. Then, adjust the Effects 1 Send knob with the appropriate track. It just may work. If not, then you need an effects device. Keep the amp turned down and experiment with all the levels.
As far as a source for mixing down, I guess a boom box could work, but I use my Sony tape deck. I think some mix down sources may throw some of its own system hiss into the mix. So, you have to experiment. Using a mixdown source with Dolby might help out with hissing problems.
I mix down to my Tascam CDRW 5000 CD burner and it works really well.
If you have a CD burner on your PC, then that may be all your need. Acid, EMagic and Cakewalk are all good choices for recording software for the PC. Cakewalk is a little expensive but has a good reputation. I use a really cheap program and it works well for me. I use Magix Audio Studio and MIDI studio and it is no more than $50 in the computer store. I think it works really well and gives you lots of great EQ, 24 tracks, stereo tracks with linking between the stereo tracks, where you can move one fader and they both move. Also, you can solo and mute tracks and it has good built in effects for reverb, delay, etc. For $50 you cannot go wrong. Go to
the MAGIX home page at magix.com for more info on the software.
And for your question of how to do it on the computer:
When you record to your 414, put the Pitch Control wheel all the way up to its highest position at hard right. It will move faster and unfortunately use up more of the cassette, but the hissing will be much lower. Also, use only high bias or Type 2 tapes like TDKs or Maxells. I think Memorex sucks for recording.
Then, on your 414 I think it is safe to hook up a stereo cable from the Phones jack to the 1/8 jack on the sound card of your PC. Make sure both ends are stereo with the 2 black rings around
the metal end of it. If your cable has 1 black ring around it, go out and get buy a stereo cable. Radio Shack has all that stuff for under $10. You may have to buy some adapters to switch around on the end.
After you do all this, you can do some nice hard disk recording on your computer and make it all digital without any hiss and in stereo. You need a nice sized hard drive, approximately, 400 megabytes for each song you produce on the computer.
Bruce
