A Reel Person
It's Too Funky in Here!!!
2 things I'm curious about:
1) By chance, if you put your finger on the right tension roller when tape is loaded, while pressing play and physically preventing the right tension arm from dropping down to the bottom,... would the Play function at least work in some fashion?... (it may be sloppy and it may spill tape)... If this is the case, then I believe the takeup tension is too weak to prevent the right tension arm from bouncing down to the "break" LED at the bottom of it's travel when tape motion is activated. Adjusting the reel servo positions and/or tension might help. NOTE: in the manual there is a typo regarding the FF and RW tension/beware.
2) By chance, have you entirely removed the reel servo PCB and reseated it onto it's motherboard connectors?
Note that I wrote this reply before viewing the 2nd video, and I hate to shoot from the hip after sweetbeats has analyzed something.
