F
fstrat76
Member
Please bear with me as I am new to this calibration and alignment stuff. I understand quite a bit of the info in the 38 manual.
I just started testing my deck.
According to the manual 0 on the meter = -10dB = .3V
I hooked up a 1kHz test tone and the source is .308 V. Looks good.
I hook that test tone source to track 1 of the 38 and select the input. 0 on the meter. Great.
I check the output of track 1 with input selected, but that reads .327 V, slightly higher than the .308 V of the source.
Now I record the test tone and play it back on the Sync head. I can see the meter below 0 and the voltage at the output reads .294 V.
I play it back using the Repro head and get an output slightly higher at .297 V.
However, my question is: What kind of tolerances are acceptable?
Thanks!
Mike
Thanks!
Mike
