Hello, Tascam lovers, I need your help.
I bought a Tascam 34b, the back foot are missing, so it stays vertical but with some tilt. It's gives it a cool look, but when I tried to correct it and put it 100% vertical, i discovered that the reason why the feet are missing!
In vertical position the flywheel rubs at the base. I also discovered there's an enormous gap/play in the capstan.
Looking at manual, apparently there's no part missing, but I read somewhere there's a rubber washer between the base, just Above the metal washer represented,but it's not drawn in manual (see picture).
So what will be the dimensions of this washer and I overcome this problem?
Also how is the order assemble? Flywheel, metal washer, rubber, shaft or
Flywheel, rubber, metal washer, shaft??
Thanks
Thanks
