Muckelroy said:
I just got done talking w/ a colleague of mine, and he said that if I were to use 499 tape, I should calibrate it no hotter than +6 dB, due to the narrower track width of the TSR-8. Quantegy's calibration specs are really meant for the wider bandwidth, pro-model tape machines (according to him. I believe he's right.) He told me that calibrating a TSR-8 to 499 tape specs will push distortion and clipping RIGHT off the bat due to the higher saturation of the narrower track bandwidths.
Seems about right. However I'd much rather use 456 tape, because I feel more comfortable with something that's the STANDARD all around. So it would probably be a good idea to run 456 not at +6 (370 nWb/m), but at +3 (250 nWb/m), which is the factory default setting of a TSR-8 (right?)
Should I then set the bias to 3.0 (as quantegy says), or keep it at 2.0 (as the TSR-8 is set to)?
If I did all this, could I then use dbx, no problems, and have awesome recordings with that hot, punchy drum sound to it all?
Well, tell your colleague the TSR-8 is more than capable of using even Quantegy GP9, as I had mine set for it. 8 tracks on 1/2" is no more narrow than 32 on 2", and the TSR-8 is an exceptional machine all around. Not all machines of the same track width are created equal. By the time the TSR-8 came along in 1989 head design had improved over older standards.
The TSR-8 outperforms many older machines with wider track width. But as I said previously, when you increase signal (flux) level you will affect the other specs, such as crosstalk and distortion. That is not bad within limits -- just different. You can't drive tape into saturation without reducing frequency response. So if the goal is compression conservative settings won't do.
+5 (320 nW/m) is recommended by Tascam as the alternate setting for 456 w/o dbx on their machines, as it is for many other manufacturers. You don't need to trim levels down to +3, unless you use dbx.
For other brands or narrower formats, such as Fostex E-16 or R8, the above recommendations will vary.
The bias setting recommended by Quantegy is dependent on record head gap length and tape speed. It is not the same for all machines across the board. The Tascam spec is a good starting point, but even bias is not set in stone.
The TSR-8 has a huge range of capabilities -- factory recommendations are just a starting point. In fact, a manufacturer is not necessarily the best authority. With nearly any product, tips and tricks develop through experimentation into field practices, which were untried at the time the product was introduced. Show me ten identical machines owned by ten experienced professionals and I'll show you ten machines set ten different ways.
As you can see there is a wide range of settings for a given machine/tape combination. If you don't like a change you just change it back. That's too much for some people to handle, especially when looking for one right answer. In that case the only real consideration is the limitations one places on oneself. So any further discussion of tape compression is really just academic because the answer will always be to leave it at factory settings.
Experience gives one a different perspective. When I get behind the wheel of a car I don't have the reservations that I did when I was learning to drive at 15, because now I know how to drive.
