B
Beck
Guest
Sorry, but that's dead wrong. Restore points are nothing more than data saved to the hard drive. Just be virtue of existing they place no load whatsoever on the CPU or memory. Moreover, OS files can become corrupt, even if a system is completely malware free. Without a restore point, your only option is re-install the OS. This is very bad advice.
Nope, as usual my advice is exceptionally good... even if it goes against most of what you think you know and what you've been told. Microsoft's "Features" like System Restore were made so any dumbass can use a PC. No one in their right mind would have that feature running while recording/editing. System Restore is constantly alive and processing when turned on. It's the first thing you should disable after a new install (For a DAW). We're talking about using a PC for a top notch professional DAW here, not as a general purpose PC. First you need a different PC than your home PC to setup a decent DAW and then you need to optimize it for recording. Anything short of that and your just a kid playing with toys.
I know how and why file systems become corrupt. I also know what a bloated albatross MS OS's have become over the years. System Restore is a nice idea, but as with many MS OS features it does not work as advertized. In addition to recording for the last 35 years I've been an IT consultant for the last 15. People call me when their staff IT people can't figure it out, and often when they've f*cked it up worse than it was before they tried to fix it.
The idea that a stock PC and OS as installed by default will make a good DAW is absurd! It takes extensive knowledge of your hardware and software and careful planning to implement a solid system.
