Miroslav - I had checked the document already... there really shouldnt be much to this, but I can't get it going!
Beck - My setup is JH-110A (striping on track 7 as track 8 is being funky)>JL Cooper PPS-1 ver 3> Alesis io26 interface>Reaper DAW... my console is bypassed in the chain but I can monitor the channel and hear SMPTE being striped.
There is a separate tone present if switched to FSK. There is an external switch to choose between FSK and SMPTE for striping on PPS-1... maybe there is no internal dip switch on version III. I have been striping at -10 on the JH vu - perhaps I should up the level.
At the moment I have Track 7 in/out to the JL cooper and midi out from the JL cooper to the midi in of the io26. I am using Reaper on a Macbook BTW - although I doubt that matters.
I can stripe SMPTE, and on playback get the lock light blinking on the JL Cooper and the midi light on the io26 blinking in unison. The transport on Reaper is set to synchronized mode. Reaper doesn't play when I hit play on the MCI, but does jump way ahead (really far ahead) when I hit stop...
Midi cable is newish - purchased about 5 years ago and never used really. Power adapter is not original but is putting out 9vdc @ 600mA (which should be sufficient).
So something is going through... just not what I need.
I can also use Logic if you think it may be better for the task at hand... I'm just much more comfortable with Reaper.
Mike
You got PPS-1 Version Three for a dollar? Awesome!
Ok, I got ya... yep, no need to open it then. I have the original version with only one switch on the outside and the jumper inside. And your power adapter is good as long as the center pin is +V.
I do see a couple potential problems however. The lock LED on the PPS-1 should be steady on rather than flashing. If it's flashing on and off in playback mode you're not getting sync. This could be from the signal coming off the tape not being hot enough... or in some cases too hot. Either case can cause failure to sync and/or misreads. -10 VU should be good, but because of differences in machines and tape formulations you can play with that level a bit. You can experiment by recording at different levels or put an active circuit between the tape deck and PPS-1 tape input so you can accentuate and attenuate the signal until you get sync lock. I've found -7 to -5 works well for me on any tape deck using the PPS-1, PPS-2 or PPS-100 (I have all three).
Another problem you may run into after the sync lock is resolved is how SMPTE/MTC is set to receive in Reaper. I don't use Reaper, but there should be something in the MTC sync receive settings to select frame rate and offset time. Frame rate should be set to 30 FPS (non-drop) and offset time should be a second or two more than the start time of what the PPS-1 striped to tape. So if you see something like, Start Time or offset time 00:00:00:00 then add a second or two or five like so... 00:00:05:00. But wait!!! If you have a version of the PPS-1 that defaults to a start time of 00:00:30:00 then set the offset time in
Reaper to 00:00:35:00. Hopefully it just gives you an option to add a second of two like so... Offset Time 02.00 (for 2 seconds). The important thing is that it should be a slightly later time than the start time from the PPS-1.
A couple other pointers for the PPS-1.
Make sure the switch is in SMPTE position before turning the unit on and into stripe mode.
Make sure the tape is running in record with a little pre-roll before turning the PPS-1 to stripe mode. That is, the tape should already be rolling in record mode when you flip the PPS-1 switch to Stripe.
EDIT: Corrected a couple typos and clarifications for better understanding.
