Swelling Verb?
  • Thread starter Thread starter Mountainmirrors
M
Mountainmirrors
kaleidoscopic renegade
How do you "swell" the reverb on a track in CEP? I want to change the amount of reverb as a track goes along.
Thanks!
How do I get there? To a place I can control the amount of reverb at each given moment? I found envelopes to affect overall volume...
First, don't apply reverb to the actual WAV file. In the Multitrack view, apply your reverb with the little "FX" button on the track. Then look at the toolbar and find the button that says "Wet __/" (that's a picture of an envelope). Make sure it's pressed.
Now you should have envelopes on your track that control how much reverb it has.
You could also try out the FX Parameter Envelopes, where you can actually control aspects of your effects, like decay time, etc.
You could also clone the original track. Keep the original track dry (no reverb) and max out the reverb on the cloned track. Start out with full volume on the dry track and not much volume on the reverb track (you do this with volume envelopes). As the song progresses, decrease the volume of the dry track and/or increase the volume of the wet track.
