I am setting up my new Dell 4550 (2.53ghz, 256 RAM) and I have 2 drives. The c:\ drive came installed with the machine, it has XP Home on it. I have a Delta 44 card which I installed without any problems. I transferred the 2nd drive from my old machine to my new machine so I would have all my old data on the new machine. This worked fine. The problem is whenever I try playing back tracks (wavs/mp3s, from either Media Player or N-Track) from the 2nd drive (E:\ since D:\ is my CD/RW) they stutter really badly. When I play the same files from the c:\ drive they play back fine. What could be causing this? Both drives are 7200 RPM, and I had no problems with the 2nd drive on my old machine which was a klunker at 450 mhz (running Windows 2000). Could it have to do with the buffer settings on the M-Audio control panel? I've never played with these settings before.
At least I've been able to work on some mixes by copying all the files to my system drive. They play back much better than on my old machine. I'm still working on getting my Waves plug-ins working (copy protection sucks!) so I haven't been able to test out the CPU power too much.
Thanks for any suggestions!
