Well, actually, that is not true...
ANY gear that is outputting a balanced signal is balanced. It may not be balanced BEFORE it's output, but it becomes balanced at it's output. That is why there is either a:
1- Transformer at the output
2- Electronically balanced circuit at the output
Now, not all gear can take an unbalanced feed to it's input and pass it to the balanced output. You will know if this is the case if it doesn't work....
Really. A sound system I work on all the time actually uses a unbalanced feed from the console to the eq, but a balanced feed from the eq, down 200' of wire to the amps. Works like a charm!
I have seen no evidence of short balanced runs sounding any "cleaner" or less "noisier" then a short unbalanced run. In fact, I have many processors in my rack that are running +4 unbalanced in the studio here.
The "book" I mention is just about any practical life experience I have had with wiring systems together (very extensive book in this case
). Others may feel free to write there own book and publish it on here, but it doesn't change the validity of mine (which tends to be very accurate
Ed
