B
buck78
Basement Studio Help
What a great forum. I am glad I stumbled on to it. I just hope it's not too late. Here's what I have so far. It's a basement studio/practice room. I will be recording acoustic instruments with mics. Complete sound proofing would cost too much. So my primary goal is to reduce the amount of transmissinon as much as possible, focusing mainly on the ceiling. Two of the four walls boarder the existing poared concrete walls. The ceiling started at 81 inches. This immeadiately ruled out two things: a drop ceiling and a solid exterior steel door.
For the ceiling I installed 2x8 hangers between the existing joists, staggered at 2.5 ft intervals. These are pretty tight. I then installed R-19 insulation in the joist cavities. The ceiling also has resilent channel running perpendicular to the joists. The walls are 2x4 studs with R-13 insulation. Both the ceiling and walls have 5/8 inch drywall. The floor is covered with a short cut loop carpet.
So far the drywall is installed and the next step is to tape and mud. There is one beam that runs through the room. This has a soffit around it that is 8 inches wide and 8 inches from the ceiling. The post on the beam is also frammed out at 8x8 inches. All the electric will be run on surface mount conduit. This includes the lighting which will be those bulbs that have the cage around them. I plan on installing a wainscoating around the walls that will be 48 inches high. This will be 1/2 inch MDF with a poly clearcoat finish.
As I mentioned before, I'll be recording and mixing in the same room. As it stands right now the room is pretty live with just the drywall and carpet. A couch, desk and some cabinets will be the only furniture for now. Before the construction sound freely traveled from the basement to the first floor. I could actually hear our baby roll over in his crib from the basement. I am not too concerned with the walls. Our mechanicals are already walled off and should not be a huge problem when the door is installed (solid interior door). I am hoping that the ceiling will be acceptable once it's taped and mudded. What can I do if it's not?
As for treating the room what should I do? The beam soffit may cause some problems, as will the square shape of the room. Any suggestions for placement of monitoring would be great. Also any acoustical treatments (foam) and placement would be welcome also. Lastly, the room will be on it's own electrical circuit. Is it OK to have the lighting on the same circuit. It will be standard incandecesant lighting.
Thanks again.
Charlie
Thanks again.
Charlie
