Dolemite
alanhyatt said:So, anyone with direct questions…fire away
Alan Hyatt
PMI Audio Group
Color codes...explain differences in sound please!
Alan Hyatt
PMI Audio Group
alanhyatt said:On each B Series box on the front side up near the top there is a small colored sticker. It is either Red, Black or Green. This 3 micron capsule is different than our 6 micron so we shoot every capsule with a B&K, then code them. So if you need a matched pair, the color dots need to be the same color.
Dolemite said:Color codes...explain differences in sound please!
Dolemite said:
Still wondering...![]()
trew said:
The second B1 that I tested has a very slight deficiency in the low-mid to low range when compared to the first one. However, they both have the same "character"...... Is it a coincidence that the one with a scratch is slightly less robust? I don't know.
My mic also has a dot of dark green ink inside the XLR connector - I would think all the mics are marked there to have corresponding code dots put on their boxes.knowdoubt said:
What was the color dot on the package of the one that was slightly more robust please? If you can remember which box each came in.
knowdoubt said:FWIW below I've pasted the exact e-mail reply I recieved from Alan Hyatt when I inquired about the dot's.
"The color codes do not affect the sound, they only categorize the capsules sensitivity ratings, so that you can match up the mics so they record as close as possible. It does not matter if you use any color, the sound is the same, it is just the input sensitivity where you want them to be very close for matched pairs, even though they are not matched exactly, they are within 0.05dB when you get the same color codes".
He had stated in an earlier e-mail to me that the 3 colors were black, blue & red but perhaps the blue was just a mis-statement since he stated earlier in this thread that the 3 colors are black, green & red, also concidering that 'crazydoc ' has stated that he recieved a green dot unit. Unless there are more than 3 colors.
