muttley600
Banned
Well this is like part #47 in my series of rants on why guitar electronics are horrible. No system should be designed where you have to worry about cables, unless we are talking RF systems where transmission line effects must be considered.
But down in AF, it really ought to be simple. But guitars aren't properly engineered, so you have to tell guitarists things like don't use a cable longer than say 30ft.
Audibility. That is elusive, but generally if we define the audible band as up to 20kHz, and we want to ensure a flat system response, we want no more than 0.1dB deviation across that band. Now, transducers can't really do that, that's a mean test. So we lighten up on our transducers and love them as they are.
But when we aren't talking transducers, we ought to be strict. What is the #1 "complaint" against digital audio? OK, there are like 47 too . . . let's take HF attenuation at 44.1kHz. Due to filter behavior, there is always going to be some. Lavry defines an ideal in his well-known white paper, it's more than 0.1dB but a lot less than 3dB.
OK, so people gripe about that loss but should be willing to accept a 3dB loss at 8kHz? I don't get that. If we can't hear 3dB at 8kHz, we really ought to hang it up. I think 8kHz matters for electric guitar . . . maybe not everybody agrees.
But I was being nice when I described output impedance at 10K. That's only true if we don't touch our volume knob. Let's think about the completely preposterous concept of a "treble bypass cap". Let's say we have a 500K volume pot and a 250K tone pot, and we rolloff 6dB on the volume knob. We now have output impedance at high frequencies of (260K||250K||250K), let's be lazy and call that 85K. That 30pF/ft is now a huge problem.
Instead of fixing that problem, what does the treble bypass cap do? It breaks the system equally at all settings rather than having the system work at some frequencies and break at others.
And that's with a standard quality cable, nothing to be done about it. So you see people shopping for super-low capacitance cables? Insane!
How about . . . lowering the output impedance with a transformer (or an active buffer, that works too but I like guitars to be fully passive)? I mean, does the gain control on an amp not work, or something?
msh, with the greatest possible respect you are off on one here. The guy wants to know what cable to get and if it matters that he pays "monstor" dollar.
You might want to hear or explain away a difference but there isn't one.
