F
Fontcow
Pardon me if this isn't the proper forum to post this, but I just received in the mail my new MXL 603s mics and took out my mixer from being in its case for the past few months to test them. I did a check through on all the buttons/knobs after being out of use for a while and to my horror the Mute button on channel 8 is stuck in the Mute position rendering channel 8 unusable. When it is depressed, it doesn't "click" and disengage. It just kind of kind of pushes in and out a bit, but doesn't click. Bummer.
Is this a common thing that will happen to eventually all of the buttons and just how expensive is this going to be to fix? And just where do you take high-end equipment like this to be fixed so somebody doesn't screw it up?
Chessrock, since we're both in the Chicagoland area, where do/would you take a mixer to get it fixed/cleaned?
