As a basic rule of thumb, if your heat is on, you MUST humidify your guitar.
If the temperature is below 30 degrees, use two humidifiers in the case.
Unless you live in a swamp, you quite simply can not over humidify it.
Oh, and I would strongly suggest that you never trust room or whole house humidifiers. In a typical house during a real winter, they can not get the humidity high enough for your guitars without causing damage to the house. The water starts to condense out on your window sills at about 35%, and will rot out your wood windows, and it will also condense and then freeze on your framing members, which will cause your framing to rot come spring and summer. It will also cause the exterior paint on your house to loose come loose. Room and furnace humidifiers are great for making you more comfortable, but lousy at making your guitars comfortable. When you aren't playing it, keep your guitar in the case, and use good humidifiers with larges sponges that are easy to fill. Soap dish humidifiers and the Kyser Lifeguards are the best, hands down, you should be using both, and I never recommend any other products. Everything else I've seen is either too hard to fill, too small, or has a hard plastic case that can damage your guitar (or in at least one case, all three).
Light
"Cowards can never be moral."
M.K. Gandhi
