T
tlee2951
Hoping some of you home-recording gurus can help me out. I'm new to the forum and relatively new to home recording.
I've had a strange snap crackle pop problem for a while. I've tried a number of things suggested on the forum from earlier posts which have helped some.
My setup is nothing to get too excited about. I'm planning on updating my sound card, software (to Sonar), and PC (in that order) within the next year or so but I'm hoping I can at least get a usable setup before going all the way down that path.
My PC is an HP Pavillion 9000 series running Win 98SE, 192MB RAM, dual hard drives (160G Western Digital 7200 RPM for audio, factory 10G drive for everything else), Create SoundBlaster PCI, Cakewalk HomeStudio 9. I've done alot of MIDI stuff for a while but I'm just starting to do more with audio.
I've done all the Win98 stuff I've seen suggested and have gotten to the point where usually when I record the first audio track it sounds fine, with no snap crackle pop. I usually do everything MIDI first and only do limited audio recording---which is good since HomeStudio9 doesn't give you a whole lot of audio tracks.
Here is the problem:
After the initial audio recording, it seems like nearly anything I do to the audio after that point will result in added snap-crackle-pop in the modified audio.
For example I usually like to normalize my audio tracks but when I take a perfectly clean original audio track and normalize it, the result almost always has new pops.
Same thing happens when I take my audio tracks and do a "mixdown to file" within HomeStudio.
Even stranger to me still is that often just by copying a perfectly good .WAV file to somewhere else, the copied .WAV now has new snap, crackle in it. I can pull up both .WAV files in Cakewalk and look at them and they look identical except that the noisy one has noticeable spikes in the waveform that match where the pops occur. I noticed also that some of the demo audio tracks that install with HomeStudio that look good on the CD are full of pops after being copied to the hard drive during install.
The .WAVs I've experimented with are all stereo wav's and I've also noticed that these pops seem to always show up in only the Stereo-Right portion of the waveform.
Anyone else dealt with this problem or have an idea? I first thought all my problems were soundcard related but now I don't know if it's Cakewake HS9 or Win9x or drivers or just my crappy PC (I woudn't recommend HP Pavillion to ANYONE).
If anyone can help me figure this problem out I will be eternally grateful.
Also are there other forums better suited to this type of question?I've looked around a bit and this one seems to be one of the best.
Many thanks.
Many thanks.
