gentlejohn
Okay, so I got hold of this Space Echo [an RE-201]. As with practically everything vintage I acquire these days, it was in need of a service so I left it in with a tech.
Here's the thing .... it's sounding great as a pre-console, in-line effect unit (eg: using it as you would any regular, standalone guitar pedal) HOWEVER this is not the main reason I bought it - I bought it to use in the Effects Loop of my Tascam 388 as a 'Mixing Stage' global effects unit. Something I could send signals from numerous pre-taped tracks to. Don't get me wrong, there's sure to be ocassions where I'll disconnect it from the Effects Loop and use it in-line on individual sources recording 'with effect' (like electric guitar for example) but this was not my main intention nor reason for investing in this.
The problem I'm having is that, post tech service, I now KNOW that the Space Echo is functioning as it should, in fact, it sounds REALLY good when used in-line! The problems occur when I try hooking it up to my 388 to use in a global effects loop capacity and I just can't work out what I'm doing wrong this end! When trying to use it in this way, the sounds I'm really liking when using it in-line 'effectively' turn to mush - I seem to be losing A LOT of the clarity!
I wonder if anybody can sort me out here as this is really dragging on for me & massively interrupting my workflow. Any thoughts/help/advice would be VERY much appreciated!
Here's how I currently have my Effects Loop hooked up:
Tascam 388 'EFFECTS OUT' 1/4" jack > Space Echo 'FROM THE PA' 1/4" jack input
Space Echo 'OUTPUT' 1/4" jack > Tascam 388 'EFFECT RETURN 1' 1/4" input jack
Here's how I currently have the Tascam 388 console controls set:
'EFFECTS MASTER' (send) dial: 3 o'clock
'EFFECTS RETURN 1' pot: 3 o'clock
'EFFECTS RETURN PAN' pot: 12 o'clock
Individual 'EFFECT SEND' pots for each channel: anywhere between 9 o'clock and 2 o'clock depending on the amount of effect required for individual pre-recorded dry sources.
Here's how I currently have the Space Echo dials set:
ECHO VOLUME knob: 5 o'clock (FULL up)
REVERB LEVEL: 9 or 10 o'clock
INTENSITY + REPEAT controls: around 12 o'clock for now
THAT BIG DIAL IN THE MIDDLE! (Delay Effect Presets): whatever feels right for the beat
OUPUT GAIN switch [H/M/L]: I've been switching between 'H' & 'M' trying to find what works
The annoying thing is, I've now spent HOURS tinkering with this set up - trying to get the two units to 'speak to one another properly' as it were and just do what I want them to do. Unless I'm very much mistaken, I'm pretty sure I have things all hooked up correctly yet my problem(s) persist!
In a nutshell, this Space Echo unit sounds absolutely STELLAR when used in front of my 388 console BUT when I try hooking it up to the console & using it as a global effect it sounds significantly different (but not in a good way!) Everything I send to it in this configuration just sounds like sonic mush and, to date, I end up I just reverting to my original taped DRY recordings as they sound considerably better than they do 'wet' with this Space Echo unit in situ (which completely defeats the object for me!)
I record in a fairly flat frequency neutral sound space and completely 'dry' recordings, although fine for some stuff, isn't where I want to be at ALL the time if you know what I mean! I got the Space Echo because I was really impressed by a number of videos on-line featuring the Tascam 388 in tandem with a Space Echo used as a global effects unit but mine just doesn't appear to be performing properly in this scenario (or maybe it's just ME!!!)
PS: Real sorry for the length of this post here by the way! With the settings given etc. I felt I needed to be as factual as possible because (as you can probably tell!) I'm desperately trying to get to the bottom of this! It really can't be THIS difficult surely??? I mean, it's just a MONO unit with one input & one output! After literally hours of experimentation with little success I just can't think for the life of me what I'm doing wrong here?!! I reckon I might need to get hold of another type of global effect unit in order to try a control test. Although I've had my 388 serviced fairly recently too perhaps the tech overlooked the Effects Loop section and there's an issue with it. I just don't know!
