Most boards and some software have what is called a "center dip" which means that a mono source panned straight up is actually attenuated so that as the signal is panned away from center it doesen't diminish in db. I think the Mackie's is a -6db dip but don't quote me there.
Also. look up the Hass Effect (lots of info out there). This Mr. Hass discovered that if you delay a signal and add it to the original, there is a quantifiable point at which the ear hears the delay as a seperate sound (20 ms comes to mind but don't quote me). If it is offset less than this threshold we hear it as the same sound, only fuller, if delayed more, we hear it as two discreet sounds. Tracks are often copied, panned and then one is pushed ever so slightly back (less than this 20 or so ms.) If phasing problems can be avoided this will add depth and dimesion to a mono source.
I am more inclined to put a copy on both sides and then eq them diferently. I like to play with panning so that maybe the shimmer (highs) of a guitar is slightly to the left while the body (mids) sits closer to center. The idea to get a mono sourse to envelop you without simply spreading it around with a stereo effect.
Different frequencies travel at different speeds. If you sit in a room with a guitar, what you are hearing includes a myriad of reflections coming from different directions, at different times with different tonalities.
I hope my sleep deprivation has not reduced this to useless babble
[Edited by Razor on 09-15-2000 at 00:01]
