ElegyOfficial
+1 for Matt
Why are rack units a bad idea at the home user price point?? To use them, you have two options: 1) Bring the signal through them on the way in to your computer; or 2) Record your signal dry, then re-amp through your rack.
The first is a problem because once you record a track it's permanent and and any processing you do is "printed to tape". You would have to retrack if you find you used too much compression or eq'd it wrong or something like that. The second is a problem because it involves going through two more conversion steps which always adds a little more noise. Plus, as Matt said, the advantage just isn't going to be there with prosumer level gear. The pro studios will do it because they spend the money on pristine converters and their rack gear is high-end stuff.
I second the notion of getting the UAD stuff. I love the plugs, they make a notable difference.
imho... cheers,
Matt pretty much said the same thing, And i agree now that i get more of an idea of what they really are. Thank you for your help Chili
