Hey guys.
I'm doing a paper for my class on:
Standalone Multitrack Recording Unit vs. Computer Based Recording Setup
I need to get actual user feedback for a piece in the article. So I need some feedback if you have the time. If not, I understand.
What are the the Advantages of having a Standalone Multitrack Recording Unit
(versus a Computer Based Recording Setup)?
Thanks!!!
JennyFin
OK, I'm game.  I have recorded a full length CD on a Roland VS1824CD, using a small boatload of outboard gear. I now work with Pro Tools, mostly. Immediate advantage to a newb: It will get you up and running faster, as a beginner, than most component systems. It is more portable, and therefore ideal for remote and live soundstage recordings.
  As I see it, there are 2 major disadvantages to the standalone. One, if any part of the system goes down, the whole studio may be down. If a compressor goes down in a component system, or a CD writer, it's probably no big deal. In a standalone, you need to be able to back up your tracks, often to CD-R. Lately, you can probably download WAV. files to your cell phone with the right app, but I am talking about obsolete equipment, for sure.
  Which leads you to the second major problem with standalone recorders. They aren't good at upgrades, as a rule. They haven't been built with replacable modular sections. They should be.
  Many people have chosen to use component systems with a USB or firewire powered interface or  interface and a laptop, or these days, a souped-up notepad computer. There have also been impressive breakthroughs in the technology of handheld standalones.
  I think that Zoom, a subsidiary of Samson, known for some fairly cheap gear of sometimes questionable quality, has hit on the right idea. Only time will really tell us about the build quality, but their lead, I think, will be copied by companies who build top-flight gear. With the
Zoom H4n handheld recorder, and the R16 multitrack, they have built machines that are standalone recorders, and are *also* USB powered computer interfaces. They can transfer WAV. files, and talk to most audio processing software, or record to onboard SD cards.
  The biggest limiting factor in any standalone is the preamp(s). If you've got $1000+ per channel preamps, they just aren't going to be in that standalone. In some cases, you can bypass the standalone's preamps by sending it a signal which is already digitalized. That's what I did, mostly, recording the CD I mentioned above. I had 18 tracks, but only 2 at a time that were good channels. Here's hoping that some of that is useful to you. -Richie
