The above trick and advice is good.Jimmy D. said:Massimo,
You could try the pencil trick - loosen the strings and put a little graphite from a sharp tipped pencil in the slot. That should stop the squeak - but it probably means you need to have that groove filed a bit, since it sounds like it may be 'binding' the string.
Hope this helps..
Jim
