famous beagle
This may be a stupid question, but what the hell.
Until now, I've just had to use my boom box as a monitor when regarding. But I finally got some separate monitors and an Alesis RA 100 power amp, and I'm not sure which cables to use.
My speakers have the push-clip-type of connectors (the kind where you shear off the wire and stick the bare wire into the little clamp. The RA 100 has these as outputs, as well as phono jacks.
In the RA 100 manual, it says that the push-clip type are the preferred method because the connection is better, but it says that high-quality cable should be used.
So my question is: Where do I find that type of high-quality cable? Will I be forced to make my own?
Please help!
Thanks
Please help!
Thanks
wire because it has a better conductivity to weight ratio than copper, or their beloved >>silver<<.
