mshilarious
Banned
So, to be extra specific here, does the above include the situation where I have part of the back of the "Open back" cabinet covered by wood? (About 1/2 of the back is covered in Blues Jr)
That just makes the path length a bit longer, but only on one axis. Once the opening gets sufficiently large, it no longer acts as a port. Instead, you just get cancellation of low frequencies according to the size of the (non)enclosure.
I should do more research on ISO boxes but from what I can tell so far, to keep the noise level down, they are sealed. So there is effectively one big box, separated into two sections by a speaker with (i can't beleive this) no air flow between the two halves. Can you comment on this?
If an iso box was designed that way, it would clearly change the low frequency response of the amp, because you are changing from an open-back design, which is effectively a baffle of limited size, to a design that is effectively either a very large baffle or a sealed box, depending on the volume involved.
Rather than try to get too deep into the theory, it's easier to just measure the amp inside and outside the enclosure and note the change in response. This doesn't have to be done at volume, as I stated acoustics are linear.
