rayc
retroreprobate
My monitors take coax, SPDIF and standard line. My interface can handle these.
Which results in best audio?
I would never use a digital link to monitors for two main reasons...
1) Unless the monitors are VASTLY more expensive than the interface feeding them the converters are likely no better and possibly worse than said AI.
2) I want an analogue pot in the signal path to dive for when (not IF!) the digitals go apeshit at 2am. Not happened to you? You have not played with MIDI then!
One possible counter? If you had a pair of cheap ass "gotboxes" with S/PDIF inputs it would be a convenient way to drive those.
The digital conversion issue (which I hinted at) I agree with, but...
...in a powered speaker, how does the analogue input have any more easy access to level control than the digital? Surely there's a pot tucked somewhere (probably on the back, in the least convenient spot) that would control the monitor levels whatever input you use. Similarly, I'd assume that the monitor out on the AI would control levels whichever output you use.
You must have bad luck with your MIDI. I wonder if it's been talking to your web browser as well?![]()
