R
rocksOff
how are the preamps on these?
chessrock said:Same as the Spirit M series, which are supposedly the same as the Ghost.
That's right. But neither are the preamps on the M-series.Rev E said:But the preamps on the E-series are NOT the Ultramic preamps that are on many of soundcraft's other boards.
Rev E said:I've used Soundcraft boards for a great deal of work (mostly live) and I am quite fond of their mixers... but if Soundcraft says that the E series and M series pres are the exact same then something is very fishy. If what Chess says is really true then the effective difference between an M series board and the E series equivalent is a digital output.
Sounds kinda weird for a spdif output to result in a $100 - $250 difference in price.![]()
DAFFYDRUNK said:And the direct outs. I didn't understand the difference until someone on here or another board mentioned the M series direct outs. I think the Future Music article complained about limitations of multitrack recording on the E series...How you'd have to use the inserts as direct outs but wouldn't get be able to use the eq in the signal. There was a couple other recording workarounds, but nothing beyond 2 simltanious tracks while monitoring. I'd like to use outboard compression, and a little mixer eq while recording a signal... That's where the M series becomes the obvious choice. The E series does visually look really cool though...
lomky said:Exactly, it has Direct outs on every channel. I would pay the extra 150USD for that.
