Big Jinx
Artist and Producer
I would suggest that anyone trying to give me assistance should turn down all headphones and monitors prior to listening to noise loop!!!
So I bought a Soundcraft Folio 10 from a friend of mine (who I no longer trust
) and low and behold..THERE WAS A MASSIVE GROUND LOOP ISSUE WITH THIS THING!! However, I did some simple freq analysis and hum is eminating between 100-300hz. Not sure if this is common, but wanted your ideas on how to fix this small problem. Console is in PRIMO physical condition so this really threw me for a loop (no pun intended). Noise is altered by using console switches i.e. main (L/R) volume, channel panning, etc. But no change when +48v is activated. Seems to be strongest when the MIX INSERTS and channels 7/8 - 9/10 are used. Any help would be GREATLY APPRECIATED!!! Pics and or any other information upon request!!
Soundcraft Console Noise Loop 10 sec.
) and low and behold..THERE WAS A MASSIVE GROUND LOOP ISSUE WITH THIS THING!! However, I did some simple freq analysis and hum is eminating between 100-300hz. Not sure if this is common, but wanted your ideas on how to fix this small problem. Console is in PRIMO physical condition so this really threw me for a loop (no pun intended). Noise is altered by using console switches i.e. main (L/R) volume, channel panning, etc. But no change when +48v is activated. Seems to be strongest when the MIX INSERTS and channels 7/8 - 9/10 are used. Any help would be GREATLY APPRECIATED!!! Pics and or any other information upon request!!Soundcraft Console Noise Loop 10 sec.
