my family just got a new house, and basically you can hear everything from everywhere.
Do you have HVAC common ducts or ducts that feed adjacent rooms or rooms below and above from the same duct? If so, this will be a problem. Even adding mass to the walls and doors, and or sealing doors, won't do diddly squat if the sound is flanking through the ducts.
Addressing sound transmission throughout a complete house after it is built is a lesson in hindsight. You CAN improve it slightly, as long as the ducts arn't common. However, IF they are not, then adding drywall, insulation, and solid doors/seals or weatherstripping is the only thing that will help. Carpets and padding will help with foot noise from the upper floors to downstairs, but sound transmitting upwards means adding mass to lower floor ceilings. Just remember, for doubling the mass, there is only at MAXIMUM, a 6db improvement.
Other than these solutions, decoupling one leaf of mass on the walls and ceiling of select rooms is the only other option. This is usually done by adding Resiliant channel. However, selecting which rooms get it is another set of criteria to sort out. Even if you wanted to, it would mean REMOVAL of the existing drywall from ONE LEAF of the walls and ceiling in the rooms chosen to get this treatment, PRIOR to adding the RC. And if floor joists support adjacent rooms, this would most certainly negate any improvement.
The truth of the matter is, sound transmission loss between rooms in an ENTIRE home should have been addressed in the planning stages, as structural isolation solutions could have been incorporated then. After the fact is not only MUCH more expensive, but difficult to achieve significant results. But this is all in the ear of the beholder. STC values are in the speech ranges, NOT MUSIC. ESPECIALLY LOW FREQUENCY. So if transmission throught the house via loud music is part of the problem...serious solutions must be sought. Otherwise your wasting your time. Thats why it is difficult to suggest absolute solutions, as absolute transmission values and criteria are unknown. Remember, there is NO such thing as soundproof. Only levels of sound transmission LOSS.
fitZ
