P
Prancer
Hi.
I am new to this site as well as to home recording. (I am not sure if I should post this to the newbie board but I hope it is ok here as it is sound forge related.)
I teach ballet and need simple software to edit music for performances. My needs are simple: cuts, pastes, fade out, adjust tempo to classical music. A few months ago I downloaded a demo of Sound Forge 5.0 from KaZaA. I had good luck figuring it out and used it very successfully. Now the demo period appears to be over as I can no longer save or burn cds from it. (I use Easy Cd Creator 4 to actually create the cds from the edits.)
My questions are:
1. I can't afford to buy an expensive program. I heard that Sound Forge XP is around $50.00. Sound Forge 6.0 is $150.00 or so. I know little about the difference between the two except that 6.0 seems faster. Do you think I may be ok with just the XP version?
2. Should I look at other programs? Cool edit for instance? Cakewalk? Do they all have "waveforms"? I need that to see the places to cut/paste.
3. Is there any program you recommend other than the ones mentioned?
4. I have no idea where to purchase these kinds of software. Probably will have to get at amazon. Are there places on the web that are cheaper? And if I wanted to purchase at an 'actual' store where could I go?
5. Sometime in the future I would like to figure out how to make cds out of my extensive library of tapes and vinyl. Is there a program I should consider now that would consolidate my edit needs with this future project?
Thank you for your patience with my "newbieness" and for any advice you may be able to offer. I sincerely appreciate it.
Lisa
My questions are:
Lisa
Were's Eddie when you need him...
