Really?
What's the name of the new burger?
I think BH was talking about tracking audio into his DAW and mixing them with his MIDI tracks, if I understood him correctly.
Anyhow, you are correct about the TB-1 and TB-6 being the preamps. But also remember there's a pair of pres (the same pres in the TB-6) in the TB-3 compressor. You can read the description of each Tool Box (that's what the "TB" stands for) from the TB-1 to the TB-10; starting from "OUR TOOL BOXES ARE AS FOLLOWS ...." in large red captial letters at:
http://members.aol.com/lhd521/myhomepage/collection.html I'm telling you, if you read it ALL in the order it comes, you won't miss it. And if you're really that interested, you'll more than likely get know the site very well and easily be able to find what you looking for.
The preamp I own is the TB-1. It's a stereo tube pre and VERY much of the colored type with its dual triode 12AX7 (1 triode per channel) and "discreet, Class A single-ended power output line driver stage!" You can VERY MUCH here the Class A in it!
I also own a TB-3 (or the TB-2 if I switch tube out of the signal path) tube compressor which has the same "Mic All" pres in it as the TB-6 does. This is such a diverse unit, I can EASILY use it on EVERY track even when doing lots of overdubs of the same vocalist and just one little turn of a knob or flick of a switch, and I can easily distinguish between tracks.
The TB-6 is a 4 channel pre (the pres alone are called "Mic All" pres) of the clean, accurate, transparent type. Simple as that; I wish it were that simple, but you can read all about that on their site. I guess you can say the "Mic All" pre has EVERYTHING in it that DaviSound stands for!
Lastly, I know I've mentioned this many times before, but just for clarification reasons (as I guess the site is just too comfusing), I'll mention again. I am having
a custom 24 channel (48 at mix) console made by them. I chose the "Mic All" pres and the TB-4 eq to be in each channel. THAT's how much I like DaviSound... For their product to be the"brain" of my studio!
But remember this is ALL simply MY opinion... Take it with whatever you or anyone else sees fit! I encourage ANY to take the risk... What all can happen? You not like it and decide to sell it on E-Bay and probably make quite a profit from it? Though I'm pretty damn sure DaviSound take it back if you REALLY didn't want it 6 months to a year down the road!
Weston Ray aka Recording Engineer
