Sonar X2 Producer Volume loss after MIDI notes edited - Please help a Newbie
  • Thread starter Thread starter 1:00AM Project
1:00AM Project
Someone please help
Sonar X2 - Running 3 separate Kontakt5 synths - a different LA Scoring Strings Div. for each Kontakt5 synth.
Most times, after I edit a MIDI note or two in piano-roll, or click on something on the screen, the playback volume for all the tracks go down drastically - you can also see this on the meters in each channel. It doesn't happen until stop the playback and restart the playback.
If I save and close the project and reopen it, the volume comes back. It doesn't happen with other projects, just this particular one.
The MIDI notes for synths 2 and 3 were originally copied and pasted from synth 1 through "pick track" in piano-roll, and then individually edited.
Please note that I am not used to routing MIDI manually through strips/channels/inputs/outputs etc. manually.
I am using the Audio Driver Codec from my digital audio interface/mixer(USB), Win8, 64-bit AMD quad core, 8 gigs RAM.
Very new to Sonar, please help.
