N
neokemit
SONAR 3 offers a complete software-based production environment that extends your customers' creativity with intuitive controls that capture and enhance their inspiration, and precise tools for accurate, effective real-time editing.
Highlights:
New mixing environment, completely redesigned UI, real-time gapless editing, Universal Bus Architecture, VST Support, confidence recording, MIDI Groove Clips, advanced MIDI routing & synth layering, multi-port MTC transmission, track inspector, full plug-in delay compensation, and more.
SONAR 3 supports DirectX & VST effects, DXi, VSTi, & ReWire soft synths, ACID Loops & MIDI Groove clips, hardware control surfaces, industry-accepted file formats including OMFI, and all Windows-compatible audio hardware via WDM or ASIO.
SONAR 3 Producer Edition Exclusives:
Per-track EQs - Channel EQ is a 6-band parametric equalizer with 5 filter types that can be individually selected for each band, as well as settings for center/cutoff frequency, Q-factor and dB gain. Features a visual filter graph to shape frequency curves without manually entering parameter values.
Ultrafunk Sonitus:fx Suite - The critically acclaimed Ultrafunk Sonitus:fx suite of automatable audio effects: compressor, delay, equalizer (parametric), gate, modulator, multiband (compressor), phase, reverb, surround, wahwah.
VSampler 3.0 DXi & Sample Library - Powerful DXi digital sampler that offers extensive editing capabilities matched by extreme ease-of-use and support for industry standard sampling formats including Gigasampler, AKAI, SoundFonts, HALion, and more.
Lexicon Reverb - Need we say more?
Highlights:
