Sonar 2 XL and audiophile 2496
  • Thread starter Thread starter DarkCide
D
DarkCide
Member
I'm using the S/PDIF on the Genesis 3 to record with sonar, please give me the correct setting for the following:
playback timing master
record timing master
the input and output for the tracks I want to record on
and for the mixer audiophile control panel, please give me the setting for the patchbay tab, hadware setting and SPDIF tabs.
thank you.
The settings may be different depending on which OS you are running,I'm running XP
PLAYBACK TIMING MASTER/M AUDIO DELTA AP MULTICHANNEL 1/2
RECORD TIMING MASTER/SAME AS ABOVE
INPUT/R/L/OR STEREO SPDIF
OUTPUT/YOUR CHOICE
PATCHBAY/MONITOR MIXER(BOTH)
HARDWARE/SPDIF IN (SET THIS TO THE SAME SETTING AS YOUR GENISIS AND SONAR,THE BITRATE CAN CHANGE BUT THE SAMPLING RATE CAN NOT CHANGE AT ALL ONCE YOU SET IT YOU MUST LEAVE IT AT THIS SETTING THROUGH COMPLETION OF THE PROJECT)
SPDIF/CONSUMER
The patchbay settings can change according to your needs but thjis is a general setting.
WARNING:make sure your H/W in S/PDIF balance settings are correct...panned hard for stereo recording
straight center for mono.
GOOD LUCK!
