Sonar 2.2xl Drum map question
  • Thread starter Thread starter longsoughtfor
longsoughtfor
longsoughtfor
Searching for the sound
Hi - I have a basic question regarding the drum map manager. I just started playing around with it and have the following problem: I open a midi track and select drum map manager for the output tab. When that dialog opens, I select "new" but when I try to selct a preset, there is nothing in the preset pull down... it is blank. If I look in the drum presets folder under Sonar, there are all the kits.... ?
I am assuming I am doing something wrong in either pointing to presets etc... any ideas?
Thanks
Kevin.
Are they in the "Cakewalk\SONAR 2\Drum Maps"-directory or the "Drum-Styles"?
Drum maps I belive. I'll have to double check tonight. Does Sonar default to looking in one or the other? I definitly did'nt change the location of anything after the install.
Kevin.
To use the Drum Maps, they have to be in the Drum Maps-directory... :)
Well, the answer was that under Options->global->folders, everything was set to the sonar2 directory (install default?) with no subdirs specified. I changed Drum Maps to ..SONAR 2drum maps and everything worked great.
Thanks for your help.
Kevin.
