Thanks for the response, dachay!
I'm using the red clip indicator light and the peak hold number on the Master Bus. Sometimes it hits up to
0.5 and other times it can come in as low as -0.8 on this same part.
There is a pretty nasty percussive in the main vocal track at that time, which is really the only thing that I thought could have been causing it. Every thing else there is pretty tame. I didn't do the volume envelope thing, but I did select the offending transient and compressed the hell out of it, but the odd behavior persists.
So my ears are telling me that there's a nasty vocal pop for sure, but I don't think that I hear digital distortion. I'll play with it some more, but I was just really confused as to why the meter could register a clip on some passes and no clip on others and wondering why this might be. I was beginning to question the accuracy of the meter as well, but, if those aren't reliable, then wtf are we supposed to use them for? a little light show maybe?
Seriously, what is the accuracy level of these meters supposed to be? Could its accuracy be affected by soundcard, buffers, latency, any other factors?
I would like to think that I should be able to look at the Master peak hold at the end of the song and raise the trim on the Master by however much below 0 it is to basically do my own non-destructive normalization. But, if the meters have mood swings and change their readings from playback to playback,... well... that really would suck and make me question what other aspects of Sonar are unreliable as well.
Of course, it could be me being an idiot, which is a frequent occurrence. But I've checked things pretty thoroughly as far as I can tell. That's why I wanted to put the feelers out here and see if anyone else noticed this kind of thing or had any possible explanations.
Thanks!
-Jeff
